Greetings from Norway
Legacy Turbo suspension
Hi! New to this forum. I have a MY93 Legacy Turbo whit 200hp and stock topmount watercooled IC. i'm on the looks for some new springs. Would Impreza GT springs fit on stock Legacy shocks?
Welcome to the BBS. There's a few other members on here from Norway, and they may be able to provide you with a little more definitive answer. But yes, I think they should work. What year Impreza are you looking to use? If it's from the mid 90's to early 2000's, the should be fine.
Mattheww044
A friend of mine had springs to a my97 impreza that i borrowed today. What i found out was that the rear springs fit with no modification, but for the front springs i'll need a new topmount. Not the bushing, but just that plate where the spring sits. nothing more is needed.
So, easy job, and a hell of a lot more springs to choose from
