FMIC install...
Posted: Sun Apr 18, 2010 3:28 am
by logan9691
I know it isn't very far yet since I got called into work this afternoon but I'm finally starting my FMIC install, gonna be pretty awesome when its done though.
Re: FMIC install...
Posted: Sun Apr 18, 2010 7:45 am
by kimokalihi
NICE! Some day I will follow in your footsteps.
Re: FMIC install...
Posted: Sun Apr 18, 2010 7:53 am
by logan9691
Haha thanks right now there isn't much to follow in right now.
Re: FMIC install...
Posted: Sun Apr 18, 2010 10:19 am
by kimokalihi
True but you are a lot further than I am. I just finally got my Ypipe extended yesterday and now my intercooler fits and is ready to be mounted permanently but I still have to figure out some hoses below it and remove the damper on my clutch and then after that I have to figure out my bypass valve setup.
Re: FMIC install...
Posted: Sun Apr 18, 2010 7:47 pm
by Mattheww044
very sweet, I am gonna do FMIC and all that good stuff too when this car isnt my DD. Ill be keeping an eye on your progress though.
Re: FMIC install...
Posted: Mon Apr 19, 2010 4:12 am
by logan9691
Re: FMIC install...
Posted: Wed Apr 28, 2010 7:25 pm
by Florin1
what kit did you go with? I'm currently researching...
Re: FMIC install...
Posted: Wed Apr 28, 2010 9:13 pm
by logan9691
Bought the core and piping separately. Core is a godspeed type L and the piping was from ebay, but I dont think you can get on there anymore, but you can get them through there actual website.
http://www.4caroption.com/product/1972/ ... ing_Polish
I also had to get some different size couplers and I get all of mine from siliconeintakes.com
If you look at my pictures you can see that a couple pieces of the hose (exhaust hose atm) are longer then traditional couplers (usually 3") I just ordered a 2' piece of 2.5" silicone hose to replace those (except for the turbo outlet) and I will also use about a 5" piece for the cold side of the core. I'm also going to use a 2.75"-2.5" 90 degree bend to connect to the throttle body and cut pipe that is suppose to go there, this will help the pipe fit better. Once all of the test fitting is done (which is taking longer then expected) I will take the pipe in to have my BOV flange welded on. I don't have a picture but my brother cut the flange that comes already on the pipe since it's in a bad place and to big for my BOV.
Re: FMIC install...
Posted: Wed Apr 28, 2010 11:58 pm
by Florin1
Re: FMIC install...
Posted: Thu Apr 29, 2010 12:40 am
by logan9691
Probably. The only reason I didn't get that one was because of the size of the core and it possibly causing problems with getting the bumper cover to go back on. If you look at mine, I was able to get it up and back far enough that I don't think that it will be a problem getting the bumper cover to fit over it. Remember, our cars are really in no way made to have one of these (FMIC) put on them so the more compact you can go (without compromising efficiency) the better. This is my opinion from just watching the whole install process and realizing how much of a bigger pain in the ass it might have been if the core was any bigger then it was. For comparison sake we compared my Godspeed core to the Perrin core on my brother project wagon and they measured up to be almost the same same (height x length) his was just a little wider.
Re: FMIC install...
Posted: Thu Apr 29, 2010 1:03 am
by Florin1
yeah i was thinking the same thing. i just cant find one w/ a smaller core.
Re: FMIC install...
Posted: Thu Apr 29, 2010 5:31 am
by logan9691
Godspeed sells an entire kit with the same core as mine, its basically it's an identical kit to mine I believe, but it's for a WRX. The only reason I didn't get it is because I was hoping that the piping for the GC8 impreza might fit my car better, but that wasn't really the case.
Re: FMIC install...
Posted: Wed May 05, 2010 7:19 pm
by macipusy
What are the dimensions of the core?
Re: FMIC install...
Posted: Thu May 06, 2010 12:41 am
by logan9691
macipusy wrote:What are the dimensions of the core?
20" x 9" x 2.5"
Re: FMIC install...
Posted: Sat May 08, 2010 1:06 am
by yazmo
im so jaleous guy lol
i wish i know more mechanic and have the right tools or friend that would help me
its so crazy all the tweak that can be done
each and everyday i am more interested
i live montreal , quebec so if anyone is around let me know hehe
nicew work with the fmic
