door locks
Posted: Mon May 17, 2010 4:46 am
by crashnburn
I am having a problem with my front passenger door lock, the lock is turning and locking when I begin to pull on the door release handle, so the passenger has a hard time getting out of the car unless your hold the lock on unlock and pull the handle. I took the door card off and I still can not figure this thing out. I am going to need some help with this. I am going to post a youtube video shortly.
http://www.youtube.com/watch?v=XWjbBf8Xax4
Re: door locks
Posted: Mon May 17, 2010 5:08 am
by cj91legss
i want to say awhile back i had a problem similar to that. i think what i did was replace the door handle (Inside) and it fixed it.
Re: door locks
Posted: Mon May 17, 2010 5:45 am
by crashnburn
sounds like I need to take a trip to the junkyard. thanks I will try that.
Re: door locks
Posted: Mon May 17, 2010 12:13 pm
by evolutionmovement
The plastic pin that holds the return spring for the handle has broken. Replace it with a metal pin. A search should get you the instructions.
Re: door locks
Posted: Mon May 17, 2010 6:09 pm
Re: door locks
Posted: Wed May 26, 2010 4:54 am
by crashnburn
update on this problem. went to the junkyard and picked up a new lock for 10 dollars.
