overheated, won't start now
Posted: Thu Jun 03, 2010 12:33 am
First off, great site. I've found lots of useful info that's helped me out a ton. I never thought I'd be able to replace a timing belt on my own but thanks to the posts here it wasn't as bad as I thought it would be.
Now my problem. My car overheated and it looks like the water pump was shot so I replaced it and the thermostat. I've got a 4EAT so used the access hole on the bell housing to lock the crankshaft to torque the bolt. I made sure all the alignment marks on the cam and crank sprockets were TDC but the engine wouldn't start after everything was back on.
I heard what sounded like grinding metal and it seemed like the engine was misfiring. The oil was full but I noticed that the notch on the crank pulley didn't line up with the timing marks on timing belt cover when the cams are TDC. I had the crankshaft lined up before I tightened everything but now it's not. I wouldn't think tightening the crankshaft bolt could cause only the crankshaft to move since the timing belt was tensioned.
I'll probably have to take the timing off again and make sure everything is TDC again but should I check for anything else before? I was thinking of doing a compression check. I have a 94 4EAT NA.
