Idle air injestion, g/sec?
Posted: Fri Jul 02, 2010 5:54 am
by skid542
I'm working on setting up some of the values in my fuel tune and I have some options for idle conditions. One of them is a MAF limit that limits the signal sent to the ECU. This is based off air intake at idle.
So, in gram/second, how much air do our motors roughly injest during idle?
Thank you.
Re: Idle air injestion, g/sec?
Posted: Fri Jul 02, 2010 3:04 pm
by wtdash
Lee,
Found this on
USMB, which states it shouldn't exceed 4.8 g/sec.....this is on a '97 EJ25, but I'd bet it's going to be very similar, since they use the same MAF system (albeit the JECs/AUTECS version).
GL,
Td
Posted: Fri Jul 02, 2010 6:31 pm
by skid542
Todd, thanks for the reply.
4.8 g/sec seems really low to me. Maybe it isn't, but 4.8g is not much at all. I just want to be sure the value I put in is correct so I don't lean it way out at idle.
Any other inputs?
Posted: Fri Jul 02, 2010 8:02 pm
by IronMonkeyL255
could always find the voltage from the MAF at idle on a stock-ish car and backtrack from there, couldn't you?
Posted: Fri Jul 02, 2010 9:31 pm
by skid542
Well that's what I'm hoping someone can give me or they can plug in one of Vikash's tools and tell me what it says at idle
. I would do this myself except I've converted to a speed density system and no longer have a MAF.
But yes, if I had a voltage I could back out the injestion.
Posted: Fri Jul 02, 2010 11:33 pm
by BSOD2600
According to RevScan (which I strongly suspect uses a calculated airflow based off the MAF voltage) from a 13 sample collection...
Idle (rpm) = 750 (avg = 752)
Airflow [JECS] (g/s) = 2.6 through 3.4 (avg = 2.72)
MAF [JECS] (volt) = 0.94 through 1.02 (avg = 0.98)
Posted: Sat Jul 03, 2010 12:58 am
by skid542
^^^ Perfect!
That's exactly what I needed to know. Many thanks!
Posted: Fri Jul 09, 2010 6:40 pm
by IronMonkeyL255
Ya beat me to it.
I was about to go plug in my evoscan to grab it........
