Random lean conditions
Posted: Thu Jul 22, 2010 5:26 pm
So the past 3 mornings, after 10 minutes of run time, my AFRs increased all of a sudden. They went from normal up to over 17:1 at idle and cruise.....I didn't try anything in boost for safety reasons.
After shutting the car off and then on a few times, the AFRs returned to normal for the rest of the day, until almost exactly 10 minutes after startup the next day, for the last 3 days straight. Turn the car off and on a few times, and it goes away everytime, sometimes sooner then later.
I hooked up a fuel pressure gauge last night and this morning when I was expecting to lean out, it happened. The fuel pressure did not change...32psi at idle and slightly higher at cruise. This rules out the fuel pump and FPR....I would think.
My next thought would be to replace the MAF....anybody got an extra good one for sale?
Also, could it be an injector problem? Any way to test this without removing injectors?
I still need to hook up the lap top to the PP6 and see if there is a deflection problem while the lean condition is happening.
I am running a PP6 with 550cc injectors and a walbro 255lph pump on E85.
Any suggestions are appreciated.
