Alarm question
Posted: Mon Sep 06, 2010 4:54 am
by cj91legss
When i installed my alarm i could not find the parking light wire.
Taken from bulldog security.com
PARKING LIGHTS ( + ) RED (+) LOW IN DRIVERS KICK PANEL
Only things is i can't seem to find the correct red wire. there's a couple. I would really like to have all of my alarm hooked up eventually. also my wife's car is the same way only i didn't install that alarm. so anyone else have success with this? or maybe someone can point me in the right direction as to where i can tie into to get the parking lights to flash.
Re: Alarm question
Posted: Mon Sep 06, 2010 6:38 pm
Do you have a multi meter that you can use to probe the wire when the lights are turned on?
Re: Alarm question
Posted: Mon Sep 06, 2010 7:51 pm
by cj91legss
yeah i did that with all the red wires that were located in the driver's kick panel and i never came up with anything.
Re: Alarm question
Posted: Mon Sep 06, 2010 8:43 pm
Have you looked at the wiring diagram from the factory manual on my server? It has wiring diagrams on there. I don't see any "red" wire that would work. However from looking at it, you should be able to tie into one of the wires going to the parking light switch.
