1995 legacy OBD 2 wiring diagram??
Posted: Fri Sep 17, 2010 3:56 am
by Subairboat
I have a Subaru EJ22 OBD2 that was taken out of a 1995 legacy with a manual tranny. I am in the States, and the car was also manufactured in the States. I am going to be putting the engine onto an airboat, so I need to know what wires I need and what ones can be removed. If anyone has a link, or any information on how I should go about doing this, I would love to know more. Please feel free to contact me for more information.
Re: 1995 legacy OBD 2 wiring diagram??
Posted: Wed Sep 22, 2010 12:47 am
Welcome to the BBS.
Here's the ECU I-O
http://main.experiencetherave.com/subar ... CU_I-O.pdf
and
Wiring diagrams
http://main.experiencetherave.com/subar ... agrams.zip
I would suggest pulling the entire harness out of the car and try to strip the extraneous stuff away from the harness so you just have the engine wiring and other pertinent stuff. There are some emissions stuff that you may either have to keep or figure a way around so the ECU does not go into limp mode. I would keep the wiring for the OBD2 diagnostic connector so you can hook up to the ECU and read any trouble codes.
