Here is what i tried so far:
If i pull that "problem" injector harness off, car runs the same.
If i pull another off, than motor really takes a dive. (but doesn't die) {this is running on 2 cyl.}
If i leave the "problem" injector/harness connected but pull 2 other injectors off, the car dies.
Another weird thing is I reversed the 2 inj. harnesses thinking maybe i switched them at some point but car runs the same. Weird. Still accelerates the same with the harness reversed on that bank.
So i know my problem lies there somewhere.
I've also tried just giving constant power to that injector (so it would stay open) but the idle didn't change at all.
I've put on a different coil pack, but still nothing...
Please give me some help because I'm out of ideas.
Car is a ej20g motor running on stock 22t computer and harness
