Torquing the crank pulley bolt
Impact240sx
Dumb question but i just did my timing belt/water pump. How can i keep the motor from turning when Im trying to torque the pully down? 2.2 Ej22. Motor is still in the car.
Re: Torquing the crank pulley bolt
Brad
1991 Subaru Legacy L AWD Wagon 5MT (DD)
2000 Outback 5MT (DD)
2005 AW STi
2010 LGT (hers)
1998 Outback (her DD)
Build Thread
2005 AW STi
2010 LGT (hers)
Build Thread
Impact240sx
What did you do? Just wrap that around the big crank pulley ??
i usually just put it in gear w/ e-brake engaged
91legacyawdturbo
There should be a small hole in the back side of the bell housing on the engine side. take the starter off and you should be able to find it, its half way down the back side of the motor, 1/4 of an inch big Take a punch and put it in there it'll lock the flywheel in place so you can safely torque the crank bolt.
2002 wrx sport wagon
Impact240sx wrote:What did you do? Just wrap that around the big crank pulley ??
yes. either hold it yourself to keep the crankshaft pulley in place or get a buddy to hold it while you torque the bolt to spec. I had no problems and it worked well.
Brad
2005 AW STi
2010 LGT (hers)
Build Thread
2005 AW STi
2010 LGT (hers)
Build Thread
