So I finally bought new engine internals but I'm still stuck on bearings. I want ACL race bearings, but ACL also offers standard sized bearings with a .001" extra oil clearance. Has anyone ever run these bearings and do you think they would be ok to run for a daily driver car?
thanks for the input,
Logan
ACL race bearing info:
VF43 custom FMIC APEXI intake Invidia 3" TBE JDM Ver. 4 RA STi trans (4.44) SPT short shifter rear LSD WRX rear axels coilover suspension JDM 4-pot front brakes drilled slotted rottors Greddy EBC tuned 20G ECU sti 550cc injectors Jecs MAF walbro 255
Re: ACL race bearing info:
I am/will be running ACL race bearings. I can't comment on the extra clearance bearings. They may use more oil due to the extra clearance, which may cause a slight decrease in oil pressure. You could upgrade to the STi 11mm oil pump and likely make up for an decrease in pressure/increase in flow.
The above comment is just theoretical. I really couldn't tell you how much if any extra oil could be used by going with the extra clearance.
You could ask mike...sorry that was low...
92 Legacy Turbo, 5sp MT, Early Large CC 20G heads, Ported custom clocked td04, Cobb catted DP, Injen SS 3" exhaust, Turbosmart MBC @ 10psi, Apexi 20g intake, custom FMIC, Fidanza 11lb flywheel, stock 05 WRX clutch
