Blower motor relay help!
Posted: Tue Jan 04, 2011 7:32 am
by Hks_bc5
Hey all, i'm having a hard time trying to locate the blower motor relay, I've looked through alldata and couldn't anything really just a vague picture so any help would be appreciated. Btw this is a 93 legacy sport turbo
Re: Blower motor relay help!
Posted: Tue Jan 04, 2011 7:17 pm
Welcome to the BBS.
Top left, figure 63-3 is the best picture I can get you at the moment.
http://www.surrealmirage.com/subaru/fil ... tion03.jpg
Posted: Wed Jan 05, 2011 11:29 pm
by Hks_bc5
thanks for the pic im going to look into it and ill let you guys know if im successful
Posted: Thu Jan 06, 2011 6:51 am
by Jessekrs123
Yes, it is wayyyy up in there way back basically on the driver's side fender. The connector is white, it looks similar to the fuel pump relay which is green. It is a lot easier to get to if you remove the rectangular thing right above the hood latch. It will most likely be on a bracket, I just took mine off the bracket and you can work on it from that rectangular cover.
