fuel pump still not working
got a stock pump replaced it and still i have no fuel is there fuses that could be blown or just the relay under the hood? or the other relay in the tank? im loosing my mind with this i want to drive my car so badd get back to me please
Re: fuel pump still not working
your gonna have to change the relay under the dash more than likely. To check if it's working simply connect your code test plugs under the steering column ( see writeup in the faq's for checking trouble codes ) and turn your key to the on position. At this point you should hear your cooling fans come on and under the dash near your fuse box you should hear a very rapid and loud clicking. The clicking indicates your main fuel relay is working. If no click, replace it.
1992 SS 5MT
She's growing faster in her old age!
alright sounds easy enough thanks i will do so and let you know what happens
ok so i pulled the fuel pump relay and it looks pretty clean idk if you can tell if there bad or not but no visual signs on it so i ordered a new one from subaru bc i have a gift certificate there it cost me 57 bucks im really hoping its the same part im talking about... so it'll be in Tuesday we'll see if the beast starts its been sitting all winter so hopefully a couple cranks will get her going lets pray for the best.....
