Part number
Posted: Fri Feb 25, 2011 5:50 pm
Part number for--The rubber protector, wire guide, with grommets that the wire bundle runs inside, that goes through the front of the passenger front door through the car body into the interior.
Don't know if this piece is available separately, or if it is a part of that section of wire harness.
You have to unpin the connectors at one end of the wire bundle to get the new grommet section on.
