EJ22 running on EJ22T ECU ?
Posted: Mon Mar 07, 2011 11:35 pm
I picked up a non-running '93 TW last Nov. Somewhere along the way, a N/A 2.2 was swapped in. It was on craigslist twice, 2 different owners, both telling the same lies about it. Anyway, I put in a turbo ecu I had and got it running in Dec. After replacing the VSS on the tranny, it seems to run a little better, but there's still something wacky going on with it. Idle jumps around from @200 to 2000 revs, unless I hold it above 1000. It drives ok, but seems to be underpowered. No CEL at the moment. I've cleaned the IAC and checked for vac. leaks. I wonder if there's any reason I shouldn't be running the N/A on a turbo ecu. The eventual plan is to drop a JDM 2.0 turbo and 5MT in, but I figured I'd drive it as is for a bit. I've done some reading and searching but am just looking for a yes or no on the current setup.
Brian
Brian
