N/A motor ran on T Ecu, now no start on N/A Ecu
Posted: Tue Mar 15, 2011 8:04 pm
by fngearhead
So, I swapped the N/A ecu back into my N/A swapped Turbo wagon. I flipped the cam and crank wires to match the N/A setup. Car ran on the Turbo ecu, not great, but it would start and drive. Now, it just spins over and won't start. I don't hear the fuel pump running when the key is first switched on. No fuel smell under the hood either. Any idea where to start looking? Maybe this ECU is junk?
Re: N/A motor ran on T Ecu, now no start on N/A Ecu
Posted: Wed Mar 16, 2011 1:01 am
by Jessekrs123
Check your fuel pump relay. It's the green one way up under the driver's side dash.
Posted: Wed Mar 16, 2011 4:35 am
by fngearhead
So, I determined the fuel pump wasn't running on the N/A ECU I had. Pumped fine on the turbo ECU. Apparently, a bad ecu then. I got another ecu from a used parts place. Car fired right up but seemed to have a significant miss at idle. As it warmed up idle smoothed out and seems perfect. Try to rev it while in park and it stumbles, misses and backfires. Can't get over 2000 revs. Two things concern me: AUTECS MAF talking to JECS ECU (no CEL), and I gave it a few revs immediately after first startup. Wondering if I screwed the learning curve, so I pulled the ecu fuse for the night and will try again tomorrow.
Posted: Fri Apr 01, 2011 6:22 pm
Is the MAF the correct MAF for the ECU you're using?
Posted: Sat Apr 02, 2011 1:15 am
by fngearhead
Currently running AUTECS MAF and AUTECS ECU. Car seems happier, but still won't rev over 2000. We got a TPS code from the latest ECU, so swapped another TPS in, but no change. I guess its time to start tracing wires and see if there's a break somewhere. Yesterday, TPS code would go away while giving it a bit of throttle and come back at idle. Junkyard parts are plentiful and cheap around here, but its time to stop tossing parts at it.
Posted: Sat Apr 02, 2011 2:15 am
by fngearhead
The car is running on its 3rd N/A ecu. The one that came with it had a dead fuel pump relay control port. Still getting code 31 after tinkering with the wiring on both ends of the TPS system. Also noticed I have nothing in pin B48 16. Its listed as non-turbo atmospheric pressure sensor in a couple of pinouts that I'm referencing. The bottom of B48 connector has obviously been opened before. The fold out lock is a bit boogered. Car currently idles perfectly, but won't rev beyond 1500-2000 without popping and backfiring.
Posted: Mon Apr 04, 2011 6:05 pm
What is an autoecs MAF? The JECS based non-turbo ECU's require a JECS MAF sensor. If you're not running one, you need to be.
The atmospheric pressure sensor on the non-turbo ECU's is internal to the ECU. You will not see any connection on that pin.
Posted: Mon Apr 04, 2011 6:22 pm
by fngearhead
MAF has an AUTECS label on it. ECU is AUTECS as well. I have a JECS MAF and ECU too, but got same results. I'm going to peak under my dash and match wiring on the wagon to mine. Someone has had the TPS related ecu connector open several times on the wagon. That's the only code I'm getting now and makes sense with perfect idle and horrible higher revs.
