Random cel after driving for 20 mins
Posted: Sat Apr 02, 2011 7:11 am
by Subiel94
Ok I'm getting the cel to come on after say about 20mins of driving. My car still runs good idles fine. Everything still seems just as it should. But soon as I turn it off it goes off. Like I turn it off to go in as in today to pick up a pizza. And come back out start it up no light. I drive for about 5 mins comes back on, but if I let it sit for a little while. No light then it's back on after 20... I connect the green connector it goes off. Should I be connecting the black connectors instead? Idk how i can pull the code if it goes off if i turn the car off? Unless i can leave it running and pull the codes? I was just thinking maybe a misfire was causing it but idk. It bothers me. I hate seeing lights on the dash. Haha any help would be awesome.
Thanks!
Re: Random cel after driving for 20 mins
Posted: Sat Apr 02, 2011 8:33 pm
by Subiel94
bump
Posted: Sun Apr 03, 2011 12:31 am
by Jessekrs123
Green connectors are for CELs that are currently being tripped. You can keep these plugged in and drive around until the CEL comes on and then it will flash the codes.
Black connectors are for the memory. I would use this method to pull CELs from the memory, so you don't have to wait around for it to trip again.
Honestly, it sounds like an o2 sensor problem. Had the same thing happen to me on my old wagon. After a little driving it would go on, then if I restarted it it wouldn't be there until I started driving again.
Posted: Sun Apr 03, 2011 1:24 am
by Subiel94
Alright sweet. I have noticed it's not getting the greatest gas mileage but the light only comes on after awhile. But alright I'll try to connect the black connectors and see if I can get anything to come up.
Posted: Mon Apr 04, 2011 6:11 pm
Another thing it could be is the canister purge solenoid. Check the codes with the black connectors and let us know what you find out.
Posted: Wed Apr 06, 2011 1:28 am
by Subiel94
So today I finally checked the codes Ik one can throw off another but the codes were
2-1 coolant temperature sensor
3-2 oxygen sensor
3-5 purge control solenoid.
So where should I start? Or to erase em do I leave the connector plugged in then drive? So that way I'll start over fresh. Even tho I had my battery unhooked for about a month or so. But all help is appriaited.
Thanks.
Posted: Wed Apr 06, 2011 1:49 am
by BSOD2600
clear them and start fresh. see what comes back.
Posted: Wed Apr 06, 2011 2:45 am
by Subiel94
well after looking what everything is. i dont have a vapor canister or any thing that would go to it. should i be worried about that? what does the vapor canister do?
Posted: Thu Apr 07, 2011 5:58 pm
by BSOD2600
It's for emissions, IIRC. Nothing serious.
Posted: Thu Apr 07, 2011 6:31 pm
Do you have those lines plugged that typically go to the charcoal canister?
As it's been mentioned, clear the codes and then check again.
Posted: Thu Apr 07, 2011 10:16 pm
by Subiel94
Nope all my lines and everything is gone. Mustve been done by po. Does my car need it? And I'm pretty sure my u2 sensor is going. I can just smell the gas and my mileage is decreasing. Does any wideband controller come with the o2 sensor so I could just buy the wideband and gauge instead of buying a new o2 sensor too?
Posted: Fri Apr 08, 2011 1:24 am
by BSOD2600
Subiel94 wrote: Does any wideband controller come with the o2 sensor so I could just buy the wideband and gauge instead of buying a new o2 sensor too?
Most modern ones do; my LC-1 does. But some recommend not backfeeding the simulated narrow O2 sensor setting back to the stock ECU since the curve levels are likely different. Although I haven't seen any definitive proof that this is a valid issue
Personally, I kept my narrow O2 in the stock location and put the LC-1 in the bottom bung on the downpipe.
Posted: Fri Apr 08, 2011 1:34 am
by Subiel94
So wait our cars have 2 o2 sensors??
Posted: Fri Apr 08, 2011 2:19 am
by Jessekrs123
Subiel94 wrote:So wait our cars have 2 o2 sensors??
No, just one located right in the cat.
If you're going to replace it go to a local parts store and get the 7/8 o2 socket. It has a little notch for the wire which makes it 10x easier to remove.
Posted: Fri Apr 08, 2011 2:28 am
by Subiel94
Ok. So would it not be fools if I just used the o2 sensor from a wideband kit?
Posted: Fri Apr 08, 2011 4:00 pm
by Subiel94
So today I cantacted prosportgauges and I asked them if their wideband kit with the o2 sensor if I can hook that o2 sensor up to my ecu bc mine is bad and they said it'd be perfectly fine, I can replace mine with theirs.. Does anyone know if this is true? I gotta save up some money so I figured id ask y'all too. Thanks!
Posted: Fri Apr 08, 2011 6:20 pm
by BSOD2600
As I previously stated, yes, most wideband sensors have a narrow O2 output. Although be warned that its simulated characteristics will be different than a real narrowband O2 sensor.
Posted: Fri Apr 08, 2011 6:45 pm
I never really seemed to have any issues with my Zeitronix WB that had a simulated NB output to the ECU. But I think the NB output will depend more on the programming.
Posted: Sat Apr 09, 2011 2:32 am
by Subiel94
Oh ok do you guys like the prosport gauges? I see a lot of ppl run em over on nasioc but I've never asked them if they liked it.
Posted: Sat Apr 09, 2011 2:33 am
by Subiel94
And according to prosport they said I'd work just fine. But idk if they are just feeding me crap to sell a product either.
Posted: Sat Apr 09, 2011 2:41 am
by Subiel94
Also will a wideband kit come with everything you'll need to hook it up? I'm sorry for all the noob questions. I'm still very new to all this type of stuff. I've been more about trucks and jeep most of my life.
Posted: Wed Apr 13, 2011 3:13 am
by Subiel94
i cleared the codes same the same codes came back up so about that purge control solenoid should i be worried about it? anyway it could be bypassed? or does my car need it i read it just goes to the charcoal canister that limits the smell of gasoline. but that cant be all that important.
