trouble codes
Posted: Mon Jun 13, 2011 2:48 pm
by the94subaru
Hi my check engine light has not come on in the 5 years I owned my car, It's a stock 94 ss auto now I'm getting a ton of codes and can't clear the ecu I tried all the steps and when I have both black and green connected I'm getting a 22 and a 52 with the black connected i'm getting 14,15,16,17,22,49 but I think they are old codes and not anything that is happening presently. I've been getting really bad gas mileage for the last 6 months like 13 to 18 I used to get mid 20's to 30 otherwise the car is running fine except now the cel is on and I'm not getting full performance. Any help is appreciated
Re: trouble codes
Posted: Mon Jun 13, 2011 6:46 pm
Connect only the green connectors and see what code comes up. You need to follow the procedure on my site to get the codes with the green connectors connected.
http://www.surrealmirage.com/subaru/engine.html
Re: trouble codes
Posted: Mon Jun 13, 2011 10:44 pm
by the94subaru
that's a nice website you have, lot of info, I will try that and see what I get. Is it normal for my fan to be turning on and off like that with the green connectors connected.
Re: trouble codes
Posted: Tue Jun 14, 2011 1:51 am
Yes it's normal for the fans to be cycling on and off when the green connectors are connected. That's a way to test whether the relays are working properly.
Re: trouble codes
Posted: Tue Jun 14, 2011 1:54 pm
by the94subaru
i pulled the fuse i thought was it and had it out all night and still didn't clear my stored codes maybe i pulled the wrong fuse which one is 14. when i connected the green connectors again this morning i got just the 52 code which i think is because i have my shift lock removed it broke on me 3 years ago and i just took it out but i never got a cel from it do you think that would be causing it if so why now is it causing problems
Re: trouble codes
Posted: Wed Jun 15, 2011 6:37 pm
The proper fuse is labeled EGI/TCU on the fuse box cover.
Code 52 is related to the inhibitor switch. I don't think the shift lock would specifically cause that codes, but I haven't had that code before.
Re: trouble codes
Posted: Thu Jun 16, 2011 3:15 pm
by the94subaru
I added oil it was a little low, got a leak in the front anyways the 22 code went away but still got the 52 code but no cel for now. is there a common spot for these cars to leak in the front I'm thinking about fixing it one of these days thank you for your help
Re: trouble codes
Posted: Thu Jun 16, 2011 5:33 pm
The front cam & crank oil seals should probably be replaced. Typically when that is done the oil pump is resealed. There is a backing plate on the pump and these screws come loose. When replacing the front crank seal it's good to just pull the pump off, check the backing screws, replace the o-ring between the block & pump, and reseal with ultra gray silicone the pump & block.
Also, the valve cover gaskets & grommets are normal leakers.
Re: trouble codes
Posted: Thu Jun 16, 2011 10:14 pm
by the94subaru
should i do the timing belt while I'm at it i don't think it has been replaced unless the former owner did it; how hard is that job, are these zero tolerance motors,
Re: trouble codes
Posted: Fri Jun 17, 2011 8:41 pm
The timing belt isn't too bad to do. If you're doing everything else and don't know when it was last replaced, it'd be a good idea.
Here's some scans for the timing belt job. The big thing is do not compress the timing belt tensioner too fastly, you can damage it.
http://main.experiencetherave.com/subar ... _belt1.jpg
http://main.experiencetherave.com/subar ... _belt2.jpg
http://main.experiencetherave.com/subar ... _belt3.jpg
http://main.experiencetherave.com/subar ... _belt4.jpg
http://main.experiencetherave.com/subar ... _belt5.jpg
http://main.experiencetherave.com/subar ... _belt6.jpg
http://main.experiencetherave.com/subar ... _belt7.jpg
http://main.experiencetherave.com/subar ... _belt8.jpg
These engines are non-interference engines.
