ECU Pins
Posted: Sun Sep 11, 2011 9:16 pm
by darkcrave
Any tips on removing these? i make a thin metal tool, its just not working for me. not sure what im doing lol
Re: ECU Pins
Posted: Sun Sep 11, 2011 9:27 pm
Once you fold up the plastic retainer on the ECU plug, you can insert that tool or very small flat head screwdriver in the back side of the pin. You'll need to push it in far enough, and then you can pull the tool and the pin out together. Once you get it figured out, it's pretty straight forward.
Not sure if that helps, but it's just something you'll have to just try.
Re: ECU Pins
Posted: Sun Sep 11, 2011 11:26 pm
by darkcrave
solved, thanks josh
