0-60 time at 92 Legacy turbo!
Posted: Mon Apr 02, 2001 8:28 pm
Hi People, I just tested my car for 0-60 timing, the different from
factory boost setting and the Boost control setting has very big
different! First I did it with 3000rpm but the car was sudden power
loss and the needle drops, then I try 2000rpm and the car runs much
smoother and fast!
I did 3 times on the factory boost setting and the first 2 times I
think I don't have good control on the clutch engagement, so the time
is pretty slow:
1) 9.32s
2) 9.27s
3) 8.63s
With the high boost setting, the time is much faster then the factory
setting!!
1) 7.42s
2) 7.41s
3) 6.93s
Also 1/4 mile time , I just did once only :
15.68s @88.3 MPH
Make good on the promise you made at graduation to keep
in touch. Classmates.com has over 14 million registered
high school alumni--chances are you'll find your friends!
http://us.click.yahoo.com/03IJGA/DMUCAA ... /X7OVlB/TM
smoother and fast!
is pretty slow:
1) 9.32s
2) 9.27s
3) 8.63s
setting!!
1) 7.42s
2) 7.41s
3) 6.93s
15.68s @88.3 MPH
