Engine will not start. tps?
Posted: Thu Apr 26, 2012 2:01 am
I was contemplating whether my jdm intercooler would fit so I can improve my bpv and piping and I had the bpv plate off the intercooler and it started to rain so I started it up and moved it into the garage and it died. I thought it was me that killed it by not giving it enough gas so I started it again and it died immediately. Then I remembered the bpv plate was still off. I bolted it back in and it won't even try to start. Just cranks for days and reaks of fuel.
I plugged the black check connector in and there's a ton of codes.
I believe these are all of them. 31, 32, 33, 45, 23, 24, 13
I should also mention I pulled the wire loom on my tps down a bit to see if it was the same connector as my spare jdm tps so that may have caused it but I don't know. Could that cause all those codes?
