Strong shudder as engine shuts off only when hot
Posted: Wed May 23, 2012 11:02 am
by 91Beater
Title says it all. My 91 shudders strongly when the engine shuts off, but only after the car is fully warmed up.
I'm guessing motor mounts, but why only when hot? I don't want to dismiss other possibilities and would like some input.
Re: Strong shudder as engine shuts off only when hot
Posted: Wed May 23, 2012 6:18 pm
by lucas
grab ahold of your engine and try to shake it by hand if you get excessive play then probably motor mounts
Posted: Fri May 25, 2012 6:26 pm
Does the entire car shudder or just the motor? Can you give us any more details?
Posted: Fri May 25, 2012 7:02 pm
by 91Beater
Legacy777 wrote:Does the entire car shudder or just the motor? Can you give us any more details?
It almost feels similar to the shudder you feel when you almost stall a manual car. All cars vibrate a bit when you turn off the engine, but mine shakes enough to feel like a shudder and only when its fully warmed up.
Posted: Tue May 29, 2012 1:38 pm
by jp233
is this an EJ22 or EJ22T?
might be trying to diesel a tiny bit ("run-on") so I would check the resistance of the fuel injectors to see if it's squirting some extra fuel in there and its catching a spark. Also timing or TPS?
Motor mounts, obviously check those.
Posted: Wed May 30, 2012 1:10 pm
by 91Beater
jp233 wrote:is this an EJ22 or EJ22T?
EJ22. TPS has already been adjusted.
