Subject: swaybar bushings
Posted: Wed Apr 11, 2001 6:22 pm
by PJHARJ
Gord, In a perfect world there should be no preload. If you set the swaybar
endlinks into the lower arms they should both make contact at the same time.
Sorry, but I don't have any torque specs for you.
PeteH
> Hi all
> i'm putting in a new set of bushings on my rear swaybar and of course the
> Haynes manual doesn't cover 1st gen .
> what i'm trying to find out is how much (preload ?) is put on the links
as
> you tighten the up. on my car now 1, the left side, is flapping and
> rattleing and the other has some weight on it (preload?)
> how do i know how tight to do up the lower bolt of the link, i assume this
> is where the weight (dpreload?) is added.
> can someone with a manual have a quick look and tell me what the torques
> should be. It seems pretty straight forward other than that)
> Thanks
> Gord
> Turbos whistle while they work
