Error code/diagnostic help, am I doing this right?
Posted: Tue May 01, 2001 9:19 pm
Hi all, last weekend I get a check engine light and boost drops back to
5.5psi MAX (I normally run 12psi with a home made boost controller). I
checked the error codes and came up with:
44 - duty solenoid valve
35 - canister purge solenoid valve
24 - air control valve (just replaced this one less than a year ago)
I have had all of these for some time, car ran fine until this one showed
up:
23 - air flow sensor
I reset the computer by disconnecting the both the negative AND positive
battery cables and let the car sit overnight (is this the correct method?)
Drive the car to work and home (100mi) and checked the error codes again,
same thing.
According to my air/fuel ratio meter the ECU is still operating the same as
before the problem, ie: it is not running full rich in "limp" mode, the AF
ratio appears to be normal.
Question: will cleaning the air flow sensor help? What can I use to safetly
clean it?
Worst of all, I have a TSD rally this Saturday, my navigator is driving down
from Detroit (9hrs) he is currently 6 points ahead in the points standing
and the second place person is driving down from Detroit so we need to do
good. I even bought a set of used Michelin rally tires to run the
event!!!!!
ANY help appreciated!!!!!!
Thanks,
PeteH
up:
same thing.
clean it?
event!!!!!
Thanks,
PeteH
