need correct vacuum routing for boost sol. please
Posted: Fri Feb 07, 2003 3:15 am
by Nate S
ok, so I have dug and dug and cant find it,
is it ,
wastegate on the top side
pressure side of the turbo on the bottom side
then the intake line on teh bottom? or is this swapped?
thanks,
nate
Posted: Fri Feb 07, 2003 3:57 am
by morgie
according to that picture i took while unpluging everything ...
all up goes up, all low goes low
up side of solenoid goes to the connector on the compressor , down side of the solenoid goes to the wastegate.
Posted: Fri Feb 07, 2003 4:29 am
by Nate S
thanks!!!
Posted: Fri Feb 07, 2003 4:54 am
by mile hi
The best diagram on the turbo hoses that I have seen came from the computer at the dealer parts counter. If you give me your e-mail I will send you a copy in .pdf format.
AL(CO)
al@iwtu.net
Posted: Fri Feb 07, 2003 6:55 am
by Nate S
emailed ya
