Canister purge solenoid valve
Posted: Fri Sep 27, 2013 9:35 pm
by ugaucin
Shouldn't the purge solenoid valve be plugged in? Or am I wrong. Its on my 1994 touring wagon. On my N/A its plugged in. Should it be plugged in the ej22t?
Re: Canister purge solenoid valve
Posted: Sat Sep 28, 2013 1:14 am
by kimokalihi
Yeah. Mines hooked up and I've run it with the hoses plugged, stock config and more recently vented with a filter to keep debris out and I honestly couldn't tell a difference between the three setups but I vote vented. Remove that canister mess from the bay.
Posted: Sat Sep 28, 2013 1:48 am
by ugaucin
kimokalihi wrote:Yeah. Mines hooked up and I've run it with the hoses plugged, stock config and more recently vented with a filter to keep debris out and I honestly couldn't tell a difference between the three setups but I vote vented. Remove that canister mess from the bay.
So it's not needed?
Posted: Sat Sep 28, 2013 6:52 am
by kimokalihi
No. It vents the fuel tank so it doesn't build too much pressure but even plugged it didn't damage anything for thousands of miles.
Posted: Sun Sep 29, 2013 10:37 pm
If you have a state inspection and have a thorough inspector, they will see that and fail it. If the hoses are there, just hook them back up. One goes to the top of the throttle body, and the other goes to the charcoal canister.
