Broke down, weird issue with startup, help asap plz
Posted: Mon Dec 30, 2013 1:58 am
Well driving down the road tonight I was in second gear coming up a hill and all a sudden slow power loss(like gas pedal in but no power) then it died completely without being able to get it started right backup my buddies and I rolled it into a parking lot right down the hill.
Immediately I checked all my silicon and vac lines and everything seemed fine. I even loosened and retightened hoping that would solve it.
Upon trying to start the car it takes a couple seconds of cranking then it starts, then sputters and immediately dies. I even try to push the gas to try and keep it alive and it does nothing. Soooo I'm getting spark, fuel and air to get it to start, but then I'm guessing either the spark or fuel pressure is lost? Only other thing I can think of is my knock sensor went bad two nights ago and we replaced it with a used one+cleaned the surface and it seemed to help tremendously(but at the same time I was still experiencing weird hesitation at most times in all boost levels)
93 tleg with a manual swap recently(the swap itself has been fine the last couple weeks).
I've got a stock airbox to snorkel to td04 with tmic.
Its dark and Sunday night so can't do much about it now. I'm supposed to be taking this thing on a big trip tomorrow so I'm trying to fix it asap in the morning. I haven't done spark plugs in a little under a year, haven't done the plugs ever, and the walboro 255 was installed about a year ago. Brand new yellow top battery as well. New alternator.
anything you have to offer as suggestions ill take to thought as I tear through it in the morning.
