Questions regarding main bearings
Posted: Thu Feb 27, 2014 6:40 pm
I'm currently knees deep in rebuilding the engine from my 93 SS.
Im going to replace the main and rod bearings, my question is, is there anything wrong with mixing ACL H(STD) & ACL HX(STD) bearing to make a complete set?
I don't have a complete set of either one , but put together I have a set. Their both standard, I believe one is coated and the other is not.
So if I put the two together, is that OK?!
To clarify , #1,3,5 are HX and #2 & 4 are H
I'm not mixing a half bearing with another half bearing..if that makes sense.
Plastigage #'s
#1 and #5 are .0015
#2,3,4 are .002 give or take a little
Plastigage #'s
#1 and #5 are .0015
