Fuel rail interchangeability?
Posted: Mon Jun 16, 2014 6:38 am
by Mdmvisuals
I have the ej22t and Im under the impression that one of the injectors is dead.
I've found that these engines are difficult to get parts for. I was told that the Non turbo ej22 fuel rails are top feed and interchangeable with the ej22t.
Is this true?
My ghia is sooooo close to being done... Just gotta figure out this fuel thing.
Mike
Re: Fuel rail interchangeability?
Posted: Mon Jun 16, 2014 3:05 pm
by cj91legss
Are you looking for stock turbo injectors? I have an intake manifold that i got in a trade deal. It has both rails with all 4 injectors. They're missing the little aluminum injector caps that screw to the tops of the rails. Mileage and condition unknown.
55 shipped?
Posted: Thu Jun 19, 2014 4:55 am
by wtdash
Mdmvisuals wrote:I have the ej22t and Im under the impression that one of the injectors is dead.
Is this true?
Hi,
No - all EJ22's - Turbo and NA- use Side-Feed injectors. The rails for the '91-'94 EJ22T are unique.
Check the resistance across the injector's pins - should be 11-12 ohms.
You can swap just one...although you may need new O-rings.
What parts are hard to find? Many parts are still avail. from the dealer or on here.
What EM are you using to run the engine?
GL,
TD
