4WD dyno or drop driveline ? HEE HEE HEE
Posted: Fri May 11, 2001 1:19 am
by ssspoon@aol.com
Found on 10 May BC-BF Legacy list
From: "William D. Robinson" <vultureboy@mindspring.com>
Subject: Dastek Unichip
I am playing with the idea of installing a Dastek Unichip and having it tuned
on a dyno. None of the dealers in my area have a 4WD dyno. If I were to
just drop the driveline to my rear diff and run the car on their dyno as 2WD,
would that work?
HO HO HO.....
Bill, yes that might work, but I can't believe you are going that senile,
along with the rest of the list.
You and a couple of others have forgotten there is a receptacle up against
the firewall on the passengers side, near the coil, that accepts a 15 amp
fuse to disable the rear wheel drive for just such a purpose. !!!
HA HA HA....
Larry shit eating grin Witherspoon
Posted: Fri May 11, 2001 1:29 am
by Josh Colombo
That's only there for Automatics.........;)
Manual's you can not disable the center Viscous coupling disc.
Josh Colombo
jcc189@psu.edu
of beats and rhythm" - ME
-----Original Message-----
Sent: Friday, May 11, 2001 1:11 AM
To: vultureboy@mindspring.com
Cc: BC-BFLegacyWorks@yahoogroups.com
Subject: [BC-BFLegacyWorks] 4WD dyno or drop driveline ? HEE HEE HEE
would that work?
HO HO HO.....
HA HA HA....
<http://rd.yahoo.com/M=131860.1389494.29 ... momsday01/> Click Here!
<http://us.adserver.yahoo.com/l?M=131860 ... =675721704>
Posted: Fri May 11, 2001 1:59 am
by Dave C
Aw yeah!
I guess i could actually dyno mine, if i really, really wanted to.
> From: "William D. Robinson" <vultureboy@m...>
having it tuned
were to
dyno as 2WD,
> would that work?
> HO HO HO.....
senile,
against
15 amp
> HA HA HA....
Posted: Sun May 13, 2001 3:59 pm
by daniel.wilson@db.co.nz
I already told you that the diff lock is for the automatics.
having it tuned
were to
dyno as 2WD,
> would that work?
> HO HO HO.....
senile,
against
15 amp
> HA HA HA....
