				Portland, OR - ISO DOHC SWAP
				Posted: Fri Dec 16, 2016 6:46 pm
				by YetiSmasher
				Looking to swap my ej22t to DOHC. Does anybody have the item's necessary for the swap?
I'm also looking to upgrade my 440 robtune to the 550. With that being said, does anybody also have ej25d rails and 550 yellow injectors?
Thanks, Ben
				Re: ISO DOHC SWAP
				Posted: Sat Dec 17, 2016 11:31 pm
				by Imprezafan93
				I have ej25d rails, and if you want to go wrx heads which i think is the best i have a set of wrx heads.
Rails-55 shipped
Wrx heads-400 shipped
				ISO DOHC SWAP
				Posted: Tue Dec 27, 2016 3:21 pm
				by robertpaige
				I've got EJ20G HLA heads. Complete with cams and all that jazz. I'm local too. PM me. I'd take $250 for em
WRX heads would be cool but you'd have to do a lot of wiring. 20G heads are plug and play with a robtune or something else.
				Re: ISO DOHC SWAP
				Posted: Sat Jan 07, 2017 7:11 pm
				by RoughDiamond
				Have a set of 20G (Legacy heads, HLA style) and a RA 5th injector manifold, if interested.
				Re: ISO DOHC SWAP
				Posted: Wed Jan 11, 2017 8:02 pm
				by chanley2010
				Im running the ej25d heads on my 22 block and they have worked great! Just make sure you use a dremel or something to modify the head gaskets and definitely look into running cometic thatare .015 thinner then stock!  Cheers
				Re: ISO DOHC SWAP
				Posted: Mon Jan 16, 2017 5:18 pm
				by dscoobydoo
				Should have come here first. I have the heads and intake. Rob also has a spare ecu of mine
				Re: ISO DOHC SWAP
				Posted: Tue Jan 17, 2017 12:24 am
				by YetiSmasher
				Ill hit you up in a little bit drew
				Re: ISO DOHC SWAP
				Posted: Sun Jan 29, 2017 5:04 pm
				by ur_a_bus
				Bump, i have a set of EJ20G heads PM for info
