Automatic transmission swap to a manual transmission year 2004
Posted: Fri Feb 14, 2020 8:38 pm
I have a question on swapping transmissions. Ive been looking at swapping out my automatic transmission for a manual transmission in my 2004 Subaru legacy outback. It has a 2.5l sohc engine in it that's got a really bad rock knock and so i going to take the engine out and replace it, so i wad thinking when i do that i could change out tube transmission as well. Ive never done this before and i am a little worried about the problems i will encounter and if i have to change it the rear end as well? Or if i need to change out the computer for the engine and tube cam shaft pulleys? And if i would need to jumper any of the electrical pins for the transmission? Any info would be amazing.
