2.3L conversion from way back
Locked
jason grahn
Post by jason grahn »
David asks:
>Woa there hold the horses.. just want to clearify that.. I can take a >2.5L
>crank and "drop it in" no modification.. and run.. it this >true? you
>sure i don't have to screw with anything..other than the >swap..
>if so how much you want for a 2.5 crank..
and Carl asks:
>Wouldn't you have to change heads or something to keep the compression
>ration from bumping up too high?????
Okay, did some extensive researching and i'm going to correct myself here...
It will not just "drop in." Other things are needed: conrods, bearings,
custom pistons, some other things.. The heads WILL NOT have to be changed
because of the compression - that's what the custom pistons are for.
In conjunction with Sass Motorsports out of Hillsboro, OR; I'll be
developing a 2.3L kit that will be available as high compression, stock
compression, or low compression (for turbos). This work will be done on a
2.2L NON-TURBO engine so we can make it safer for all 2.2L Subarus. For all
interested, email me off-list and I'll keep you updated on advances up to
the debut of the final product.
Talk to you all later!
-Jason
Get your FREE download of MSN Explorer at http://explorer.msn.com/intl.asp
Dave C
Post by Dave C »
You KNOW i'd like to be kept in the loop about this stuff :D
--- In BC-BFLegacyWorks@y..., "jason grahn" <jgrahn555@h...> wrote:
> David asks:
take a >2.5L
>true? you
> and Carl asks:
compression
myself here...
bearings,
changed
stock
done on a
For all
up to
> -Jason
Rod Grosvenor
Post by Rod Grosvenor »
Jason-now that my turbo is done, I`d be interested in the stroker kit for my next engine project. Pls keep me up-to-date. Thanks---ROD (AZ.)----- Original Message -----
Sent: Wednesday, August 15, 2001 12:50 PM
Subject: [BC-BFLegacyWorks] 2.3L conversion from way back
David asks:
and Carl asks:
-Jason
ADVERTISEMENT
<http://rd.yahoo.com/M=212508.1587435.31 ... .tf?s=5085>
<http://us.adserver.yahoo.com/l?M=212508 ... =559706245>
Locked
