turbo's in Rod Grosvenor ???
Posted: Sat Sep 08, 2001 3:03 am
TURBO'S IN ??? CAN'T BELIEVE YOU WAITED THIS LONG ???
What are you talking about? I've had you down all this time as an auto trans
92 Turbo Legacy Wagon, same as me. What's going on? What were you? What
have you done? Did you use a stock Legacy IHI turbo with water and oil
lines? Try to find a factory Turbo Legacy and check out the hood scoop and
ducting around the turbo. The stock scoop ducts cooling air onto the turbo.
Also, check out the funny little tank with a radiator cap over the intake
manifold. It is part of the cooling system that circulates water thru the
turbo when you shut down the engine. Go here to get more details.
http://www.xmission.com/~dac/library/jc_coolant.htm
Larry Witherspoon
check out additional post for my intercooler progress
ADVERTISEMENT
<http://us.a1.yimg.com/us.yimg.com/a/di/dietsmart/4.gif> <http://us.a1.yimg.com/us.yimg.com/a/di/dietsmart/1.jpg>
<http://us.a1.yimg.com/us.yimg.com/a/di/ ... rkblue.gif> You can, too! Start here...
<http://us.a1.yimg.com/us.yimg.com/a/di/ ... /clear.gif>
Height:
3 4 5 6 7 8 ft 0 1 2 3 4 5 6 7 8 9 10 11 in
Weight:
lbs. kg.
<http://us.a1.yimg.com/us.yimg.com/a/di/dietsmart/3.gif>
<http://us.adserver.yahoo.com/l?M=210544 ... =729919211>
Larry Witherspoon
ADVERTISEMENT
Height:
Weight:
lbs. kg.
