dfullerton Head Swap
Posted: Fri Nov 02, 2001 9:29 am
In a message dated 11/01/01 12:344 AM Pacific Standard Time, "dfullerton.screaming.net" writes:
Subject: Head Swap
The heads on my 94 UK legacy turbo are getting really noisy, will the heads from a 98 Impreza turbo fit?
I believe they will fit because I believe the 94 UK Legacy turbo and the 98 Impreza turbo both use the same 2.0 engine.
Wish it was so cut and dry in my case. I have 2.5 SOHC heads at Dan Paramore Racing Heads right now (Dan just got back from setting a few land speed records at the Salt Flats) but I need to find out about whether the coolant and oil passages and intake and exhaust manifolds will matchup to my 2.2 block. I also need to know the stock 2.2 turbo head combustion chamber volume. Any help would be great.
Larry Witherspoon
Torrance (Los Angeles)
ADVERTISEMENT
<http://rd.yahoo.com/M=210675.1710593.32 ... c=14856015> Click Here!
<http://us.adserver.yahoo.com/l?M=210675 ... =758100601>
Subject: Head Swap
Larry Witherspoon
ADVERTISEMENT
