91 Legacy won't start - please help
Posted: Tue Nov 06, 2001 12:49 am
My buddy has a 91 legacy wagon, which has been running a little rough
recently. (Occasional misfire, sluggish/jerky when you go on the gas)
The other day, he gave it an oil change, and washed down the engine
bay with a garden hose (while the engine was running)
When he restarted the engine later, it seemed like it was only firing
on two cylinders, yet still limping along. We thought that the
wires/ distributor may have been affected by the water, so we left
the hood up, and let everything dry out in the sun.
When we returned a day later, the car wouldn't start ... it turned
over fine, but only seemed to be catching on one cylinder.
I am pretty familiar with cars and car maintenance, but not
necessarily with Subarus. Does this sound like a common Subaru
problem? Is there a particular sensor that may have been affected by
the water? Could the fuel pump be the most likely cause?
Any help you could give would be most appreciated. Thank you
