Steering wheel/cruise
Posted: Thu Nov 08, 2001 12:09 pm
by Josh Colombo
You should be able to cut a hole for the cruise lever to pop out. I know of a couple people that have done this. I am pretty sure Jamie has done this www.subiegal.com
-----Original Message-----
Sent: Wed 11/7/2001 12:38 AM
Cc:
Subject: [BC-BFLegacyWorks] Re: Headlight Swap - 91 Legacy Turbo Sedan
Dan:
Thanks very much for the offer. I'm just wondering if its worth the
trouble of making an adaptor. The problem I find with the NA 91
Legacy's 45/65W 9004 units is the design of the reflector. It seems
to difuse the light pattern too broad (wide). There is no "forward
punch" to them at all.
I have driven a 92 and 93 Legacys and the light pattern, especially
in high beam is completely different. The design was improved
tremendously and in my opinion its because of different reflector
design.
If your passion is to invent, how about coming up with an alternate
location in changing the cruise control lever from its current
location at the steering wheel to some place on the dashboard? I am
interested in changing the stock steering wheel with a
Momo/Sparco/Grant type, but these have no application the accept
cruise control.
Roy
--- In BC-BFLegacyWorks@y..., INCEv@w... wrote:
> Roy:
> Do you want me to see if I can adapt your bulb holders to H-4? If so
> what bulbs do you have, 9004? I have a Large machine shop, and
passion
> to invent! HA Dan (Southwestern,WA{Brooklyn})
