whats next to replace?
Posted: Mon Nov 12, 2001 9:36 am
by Nissan-Subaru
After new
Plugs
Wires
02 sensors
Multiple ecu resets (it still stores an 02 code after replace… I even left it unplugged for 24 hours)
UR pulley
Change in driving habits (drive like a grandma now)
K&N panel Filter
I’m still getting 13-15mpg no matter how or where I drive… This is the same thing I got before I did the above.
It also seems like it’s still unable to put all the power to the ground sometimes…
Its also boosting steady at 8 ½
What’s next to replace?
John
91 Sport Sedan
_____
Do You Yahoo!?
Find a job, post your resume on Yahoo! Careers <http://careers.yahoo.com/?clink=foot-fp> .
Posted: Mon Nov 12, 2001 10:16 am
by Josh Colombo
When you say 02 code, I'm assuming you're getting a code 32 correct?
What I would do is test the voltage coming out of the 02 sensor. Compare that to what it should be, if it is good, you have problems in the wiring harness or some where later down the line in the wiring loom, which is not a fun thing to track down. This is most likely why you are seeing such poor mileage and crappy boost. You need to get that 02 sensor or wiring fixed, and that should fix your problems. The computer sees that the 02 is messed up and is adjusting everything else accordingly.
-----Original Message-----
Sent: Mon 11/12/2001 8:27 AM
Cc:
Subject: [BC-BFLegacyWorks] whats next to replace?
After new
Plugs
Wires
02 sensors
UR pulley
K&N panel Filter
John
91 Sport Sedan
_____
Do You Yahoo!?
Posted: Mon Nov 12, 2001 7:10 pm
by Nissan-Subaru
Yes code 32... Is anyone able to give me what the mesurments should be? (for a turbo legacy 02 sensor)
I would greatly appreciate it!
Thanks!
John
accordingly.
! Cc:
After new
Plugs
Wires
02 sensors
UR pulley
K&N panel Filter
&! nbsp; It also seems like it’s still unable to put all the power to the
ground sometimes…
John
91 Sport Sedan
_____
Do You Yahoo!?
&nbs! p;
Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service <http://docs.yahoo.com/info/terms/> .
> ATTACHMENT part 2 application/ms-tnef name=winmail.dat
_____
Do You Yahoo!?
Posted: Mon Nov 12, 2001 7:30 pm
by mike p.
i'm pretty sure it should be a steady signal of about .1-.2 volts on
a cold engine and a varied signal of .1-.9 on an engine that is up to
normal temp(in closed loop). if it doesn't reach closed loop(i.e.
the fluctuation) it's shot. hope that helps.
> Thanks!
> John
> Josh Colombo <jcc189@p...> wrote: When you say 02 code, I'm
in
loom,
you are
computer
> accordingly.
> Josh
> From: Nissan-Subaru
> To: BC-BFLegacyWorks@y...
> Cc:
> After new
> Plugs
> Wires
> 02 sensors
replace… I
> UR pulley
> K&N panel Filter
drive… This
to the
> ground sometimes…
> Thanks
> John
> 91 Sport Sedan
> _____
> Do You Yahoo!?
Service.
> Do You Yahoo!?
> Find a job, post your resume on Yahoo! Careers.
Posted: Mon Nov 12, 2001 7:50 pm
by Nissan-Subaru
i'm not sure on how to test this... i have a new o2 sensor so i know that works.. so do i unplug the harness and then take my measurments there? and does the car need to be on? please help
> Thanks!
> John
loom,
you are
computer
> accordingly.
> Josh
> From: Nissan-Subaru
> Cc:
> After new
> Plugs
> Wires
> 02 sensors
replace… I
> UR pulley
> K&N panel Filter
drive… This
> &nbs! p; It also seems like it’s still unable to put all the power
to the
> ground sometimes…
> Thanks
> John
> 91 Sport Sedan
> _____
> Do You Yahoo!?
> <http://careers.yahoo.com/?clink=foot-fp&! gt; .
Service.
> Do You Yahoo!?
> F! ind a job, post your resume on Yahoo! Careers.
_____
Do You Yahoo!?
by Nissan-Subaru
> Thanks!
> John
loom,
you are
computer
> accordingly.
> Josh
> From: Nissan-Subaru
> Cc:
> After new
> Plugs
> Wires
> 02 sensors
replace… I
> UR pulley
> K&N panel Filter
drive… This
to the
> ground sometimes…
> Thanks
> John
> 91 Sport Sedan
> _____
> Do You Yahoo!?
Service.
> Do You Yahoo!?
_____
Do You Yahoo!?
Posted: Tue Nov 13, 2001 4:03 pm
by mike p.
well, to the best of my knowledge, yeah to test the sensor you need
to have the car running and take the readings while it warms up
(should read a steady .1-.2 volts) and when the sensor hits it's
operating temp(fluctuates between .1 and .9) but that's like 600
degrees or something so it gets really hot and can melt your wires to
the voltmeter if you're not careful. also you need to probe the
signal wire which may be a bit difficult without a schematic or
something. the sensor has 4 wire terminals correct? well it's one
of those. i guess you could try em and see which registers. you'd
have to have the + on the signal wire and the - of the voltmeter on
the ground wire of the sensor. if you get a wire with high voltage
(+12volts) that's not it, if you get one with 0 volts, that's the
ground, if you get one with .2.6 volts or something near that, that's
the signal wire. you should be able to put the probe down into the
back of the connector so it touches the terminal, if you can follow
the wiring up away from the sensor itself you could probably probe
there to and eliminate the worries of melting your gear but you'd
probably have to bear a bit of wire in order to probe unless you can
find another connector. well, my brains fried now so i hope that
helps, any other questions post em and i'll try to answer.
> "mike p." <ob1poor@y...> wrote: i'm pretty sure it should be a
to
should
> > Thanks!
> > John
problems
> in
wiring
> loom,
> you are
02
> computer
> > accordingly.
> > Josh
> > From: Nissan-Subaru
> > Cc:
> > After new
> > Plugs
> > Wires
> > 02 sensors
> replace… I
> > UR pulley
> > K&N panel Filter
> drive… This
> to the
> > ground sometimes…
> > Thanks
> > John
> > 91 Sport Sedan
> > _____
> > Do You Yahoo!?
> Service.
> > Do You Yahoo!?
Service.
> Do You Yahoo!?
Universal Inkjet Refill Kit $29.95
Refill any ink cartridge for less!
Includes black and color ink.
http://us.click.yahoo.com/1_Y1qC/MkNDAA ... /XoTolB/TM
Posted: Tue Nov 13, 2001 6:13 pm
by Josh Colombo
The 02 sensors are 3 wire. Positive, negative, and the sensor wire.
I wasn't able to find any specs on voltage in the chilton's manual.
Josh Colombo
jcc189@psu.edu <mailto:jcc189@psu.edu>
of beats and rhythm" - ME
Sent: Tuesday, November 13, 2001 31 PM
Subject: [BC-BFLegacyWorks] Re: whats next to replace?
to
should
> > Thanks!
> > John
problems
> in
wiring
> loom,
> you are
02
> computer
> > accordingly.
> > Josh
> > From: Nissan-Subaru
> > Cc:
> > After new
> > Plugs
> > Wires
> > 02 sensors
> replaceâEUR¦ I
> > UR pulley
> > K&N panel Filter
> > IâEUR(tm)m still getting 13-15mpg no matter how or where I
> driveâEUR¦ This
> > It also seems like itâEUR(tm)s still unable to put all the
power
> to the
> > ground sometimesâEUR¦
> > WhatâEUR(tm)s next to replace?
> > Thanks
> > John
> > 91 Sport Sedan
> > _____
> > Do You Yahoo!?
> Service.
> > Do You Yahoo!?
Service.
> Do You Yahoo!?
http://us.click.yahoo.com/ltH6zA/MkNDAA ... /XoTolB/TM
Posted: Tue Nov 13, 2001 7:33 pm
by Daniel Wilson
I will have a look when I get home I have all that data.
Dan
> Josh Colombo
> jcc189@p... <mailto:jcc189@p...>
http://us.click.yahoo.com/r9F0cB/MkNDAA ... /XoTolB/TM
Posted: Wed Nov 14, 2001 12:53 am
by acroxford@hypermall.net
The voltage swings back and forth from about .1 volt to 1 volt We
had a car that had a complaint of poor milage and low power and it had
a strange code of some sort. It ran smooth and fairly well and it
really gave us a problem. It turned out to be the coil!! This engine
runs real well one two cyl.!! That is a rare one but it would drive
the O2 sensor nuts or maybe the ECU ???
--- In BC-BFLegacyWorks@y..., "Daniel Wilson" <daniel.wilson@d...>
> Dan
wire.
manual.
> > Josh Colombo
http://us.click.yahoo.com/E11sED/MkNDAA ... /XoTolB/TM
Posted: Wed Nov 14, 2001 3:13 am
by Daniel Wilson
I have now published the info to my site.
Dan
http://www.geocities.com/subman2001nz/
Posted: Wed Nov 14, 2001 9:43 am
by Nissan-Subaru
wow nice page
Dan
_____
Do You Yahoo!?
Find the one for you at Yahoo! Personals <http://rd.yahoo.com/mktg/mail/txt/tagli ... .yahoo.com> .
ADVERTISEMENT
<http://rd.yahoo.com/M=213858.1732093.32 ... .tf?s=5085>
<http://us.adserver.yahoo.com/l?M=213858 ... =690060096>
by Nissan-Subaru
my 91 doesn't have a coil right?
> Dan
wire.
manual.
> > Josh Colombo
_____
Do You Yahoo!?
ADVERTISEMENT
<http://us.adserver.yahoo.com/l?M=213858 ... =995129154>
Posted: Wed Nov 14, 2001 10:13 am
by Rod Grosvenor
Hi-you have a coil in the center of the intake manifold just below the throttle body. It`s the item where your 4 plug wires exit. If you have over 125k on the motor, it probably would`nt hurt to replace it for maintenance. Just ask for the LATE RS coil at the dealership.---ROD (AZ.)
----- Original Message -----
Sent: Wednesday, November 14, 2001 7:38 AM
Subject: Re: [BC-BFLegacyWorks] Re: whats next to replace?
> Dan
wire.
manual.
> > Josh Colombo
_____
Do You Yahoo!?
Find the one for you at Yahoo! <http://rd.yahoo.com/mktg/mail/txt/tagli ... .yahoo.com> Personals.
ADVERTISEMENT
<http://rd.yahoo.com/M=215002.1711356.32 ... 847665/R=1>
<http://us.adserver.yahoo.com/l?M=215002 ... =131498803>
Posted: Wed Nov 14, 2001 10:33 pm
You have a coil mounted on top of the engine four spark plug wires
come out of it. The coil is just a guess the one we worked on really
ran smooth but was down on power. I was getting a bit desparate and
was removing the coil to swap it out and found a large burned crack in
bottom of one of the coils.
> acroxford@h... wrote: The voltage swings back and forth from about
had
> > Dan
> wire.
> manual.
> > > Josh Colombo
> ADVERTISEMENT
> zZz.
> Do You Yahoo!?
> Find the one for you at Yahoo! Personals.
