AT/MT from RS Swap. Speedometer Question
Posted: Wed Apr 09, 2003 5:21 am
by XeviousR
I'm in the midst of a Transmission swap in my '92 Legacy. I am removing a broken automatic and replacing it with a 5-spd manual transmission from a '98 Impreza RS. I noticed that the Impreza tranny seems to have a electronic speed sensor, while the Legacy's tranny has a mechanical speed sensor. Is there a remedy for this? I assume I can send my gauge cluster out to a speedometer shop to have it converted.. or perhaps there is a newer gauge cluster I can use?
Please check out the link below to follow my progress...
http://www.shimmysideways.com/tranny_swap.htm
Thanks in Advance!
Posted: Wed Apr 09, 2003 3:38 pm
It may be a little more complicated than that... I think in our cars the ECU senses vehicle speed through a sensor built into the gauge cluster; that conversion would also need to happen, or you may be able to use the signal from the transmission directly.
I didn't know newer Subarus had the VSS electronics directly on the transmission.
Posted: Wed Apr 09, 2003 6:35 pm
by ciper
Not seeing yours directly, my swap was as easy as removing the electronic sender and screwing the mechanical line it its place. This was from a 1990 legacy auto to a 1995 impreza auto.
Posted: Fri Apr 11, 2003 4:18 pm
by XeviousR
Ciper: Thanks, I'll try that today. I hope to drive it home today or tomorrow.
Posted: Fri Apr 11, 2003 7:47 pm
by magicmike
I know this doesn't help you but I know they make a module that plugs in series with a speedo cable and puts out a VSS pulse (vehicle speed sensor) I used to use these when installing GPS systems in later modle cars without a VSS wire.
Just some info :wink:
Mike
Posted: Sat Apr 12, 2003 1:03 am
by XeviousR
I am aware of this.. but I am trying to accomplish the opposite. I tried what Ciper suggested and it seems to have worked. I have to wait until the install is complete to test it. I'm waiting on a new driveshaft. I thought I could use the driveshaft that matches the RS 5-spd, but apparentely the RS and Legacy's wheelbase is different.
