06 fxt tmic and td04
Front, Top, Air, Water.
know1
Post by know1 »
woohoo
I finally got it done!
I'll have better pics up in a bit, just got home.
LegacyT
Post by LegacyT »
Any more pics? :)
know1
Post by know1 »
Yeah, a whole bunch. I'll sort through them tonight
QuickDrive
Lurker-King
Post by QuickDrive »
Looks like a clean install.
R I P-------- 91 Turbo 4EAT --------R I P
ScottyS
Post by ScottyS »
Cool, I am of course curious about your Y-pipe and also the BPV routing.
I re-did my Y-pipe again last night, using a cut-up aftermarket silicone Y and 2"ID exhaust steel tubing. I still don't like it, as I would like to incorporate a metal Y section in the middle.
PS - an OEM 05 STi Y-pipe would not work easily with an 06 WRX TMIC, similar issues to the eBay pipe kit as posted in the other thread.
1991 SS build thread: http://bbs.legacycentral.org/viewtopic.php?t=40430
know1
Post by know1 »
some random pictures:
coolant tank post relocation...you can kinda see the bracket.
custom f-pipe
turbo fitment and f-pipe clearance checking
engine bay post swap
bpv routing/ bov adapter modifications
*fixed*
custom f-pipe
So where did you get the BOV adapter plate? Cheapest I've found it for it $35+shipping and I don't feel like paying that much for a piece of metal with a hole in it.
know1
Post by know1 »
thanks for fixing my pics kimo, what did I do wrong?
I got my adapter from ebay, for like $30 :P
Instead of putting the URL direct link to the .jpg you put the URL to the page that had the .jpg on it. Just had to delete the ?v=0 off the end of it.
I'll check ebay out. Thanks.
ScottyS
Post by ScottyS »
Still not clear on what you used for the y-pipe.
I am running a chopped-up cheap silicone one for now, but I have a Prodrive silicone y-pipe for a FXT coming that might be the ticket after modification. I'll post the results in my thread when I get done with it.
know1
Post by know1 »
used the ebay one for 02-07 wrx
ebay link
Redlined
Post by Redlined »
Looks good! Planning an intercooler swap into mine shortly, How noticable is the differance in power/drivability with everything installed?
Also, Is that a rust spot in the back of your engine compartment? (Ninja's your Grill while your looking away)
know1
Post by know1 »
Hah, you stole my fake grill! It will now leak poisonous gas into your skin (applies real grill).
know1
Post by know1 »
It has got a lot more low end torque. Then there is a bit of a dead spot, then at about 80-90km/h it picks up again and pulls hard all the way to the cel I always eventually get :p
As for ninjaing my grill, yeah she is a beaut. I cut the cross bits out and had a friend fiberglass the holes, paint it all and put the mesh on it.
Post by SubaruNation »
Couple of Q's:
1. Did you use the oil lines from the VF11, or would the be a possibility?
2. how did you fab together the 90* intake section for the td04?
3.did you put a Piece of metal pipe in between the 2 90* connectors for the intake section?
do you have any pictures of the underside of your intercooler?
with all the piping and such?
RJ93SS
Post by RJ93SS »
i'll answer those, know1 bought a 2.5rs
1, you can use the old ones, but may as well use the new, depending on where you mount your coolant tank you might have to cut the bracket that holds the coolant lines together. it's easy as pie
2. it's just a 2" or 2 1/4" rubber 90 probably from a rad of some type, find one at napa of your choice
3.yes, exhaust tubing
