redirecting cooler air to slanty
well i been driving my JDM tdo4 and slanty ic for a couple weeks. drives fine pulls hard. just wondering is theres a way to direct the cooler air to the slanty with the stock scoop
Re: redirecting cooler air to slanty
That's about as cool as its going to get unless you go front mount.
i figured that much just wondering how i could kinda aim the air to the slanty more
Think it would be to much work. But you could try and get the unslanted WRX intercooler and that might help. Also do you have a turbo blanket and heat shield. If so I wouldn't worry to much unless you just want something to do.
i have a grimmspeed heat sheild. and i was just wondering. i like the slanty because it gives my subie a jdm look. maybe next summer i'll look for a diffrent scoop.
Yea no worries. Some guys use the RS or WRX scopes for looks and a little more air.
You could get the slanty splitter from a GC8, and slot its holes or make a bracket to mount it to our hood. It's not going to be a direct fit by a long shot.
Example:
http://www.ebay.com/itm/400691377803?_t ... EBIDX%3AIT
Example:
I run a slanty IC and i noticed a bigger difference when i went with a WRX hood scoop.
1993 legacy ss "Shela"
How many people seal the area between the TMIC and hood? Directing air through it and not around it should make a big difference.
Any one know if the slanty splitter from an early ver1-2 GC would bolt up? I have one on my car but I have a larger Intercooler so I am only feeding air to half of it.
2011 Mini Countryman S All4
1970 Honda Ct90
2001 Forester S of Doom - mowed down by a Cummins
1994/5/6/01/02/03/04/06/07/08 Impregacy OUtback SS STi Type R money pit- NEW RALLYCAR!!
1970 Honda Ct90
The holes.dont line up, but you could prob make it up.
