My rebuild is going well [vid inside]
Yup, I received all my stuff, and started the rebuilt this week-end.
I waited till being far enought to give you a little update
So this his how it goes..
All gaps were checked with Plastiguage.. amaisingly, i'm into the stock specs even without any crankshaft rework.
shortblock closed after a lot of problems finding guide-pins
all bolts torqued to specs, with some engine oil on the threads.
Pistons, pins and lock pins installed.. ahhh relief ! hehe
and the finaly assembled shortblock. Looks not pretty good especially with that rusted water-pump wheel, but in real it looks nice.. pics is bad :\ hehe i'll have to sand a little bit that wheel so rust goes away ... (that's the only pump with oil-cooler nipple i have :\ )
If i receive the guide-pins for the heads tomorrow, i'll then install the heads, water passage, maybe oil-pan too. I'll keep you updated.
All other pics, and hirez are at this url :
http://public.fotki.com/morgie/morgie/o ... age_moteur
morgie
'98 4Runner V6 Manual 4x4.
The crank is stock, but was balanced like all the pistons and rods.. hehe
rsstiBoy : In Quebec, with the bad weather and snow/calcium/etc... aluminium gets all eaten and looks pretty damn bad. The guys who overbored the block also cleaned it, and i painted the block to "seal" the aluminium, and prevent it to get more eaten / corroded. Also, it looks much better than it was ! hehe
humm.. look at this pic, you can see the block, and look how bad it was.. hehe
morgie
I can't believe how clean they got that engine. Beautiful. i like the black block. I'm leaving mine bare with dark red crackle intake and valve covers with the relief details bare.
+rep to Gunk + Dupli-Color engine emanel/paint
I had a little problem with the heads / head bolts...
2.2l shortblock + Legacy TT heads + WRX head bolts. :
after torque-ing the bolts to the specified 51lb-ft as in the WRX shop manual (step 2), the exaust-side head bolts were still slack ! like if the bolts were toooo longs, and was hitting the bottom of the fillets in the block.
Solution : i'll have to cut the head bolts 0.5-1cm shorter and reinstall them in the holes. Not soooo bad but.. annoying. hehe
morgie
- quasi-mod-o
Morgie, refresh my memory. You're building an EJ22G block with EJ20 DOHC heads right?
2000 Subaru Legacy B4 RSK
*Formerly DerFahrer*
Suby : Yup, 2.2l turbo shortblock with custom internals, the heads come from a 2.0l twin turbo legacy, but can't say the year / model.
and the WRX bolts seems to be 0.5cm too long.. hehe
After redooing the heads. i started reassemble the front.. still need some more gaskets and stuff.. but still going forward
i'm now entering the dark area of the hoses ... that scares me a little :\
morgie
Morgie,
you are what of the following?
a- self employed
b- unemployed
c- on vacation
d- you are the boss
e- calling in sick
a- self employed
b- unemployed
c- on vacation
d- you are the boss
e- calling in sick
Wow, that looks hot Morgie! I wanna do a build up too. I can't wait to see what it looks like in the car. What color is your car anyways? Black?
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
Doug : hehe in fact, the rebuilt was pretty quick.. quicker than i would have expected it ! took a total of around 15hrs to get there .. on 5 evenings, that's not so bad
Nice one Tawa, i forgot about this thread ! hehe the Obs changed a bit since i got it..
http://images6.fotki.com/v79/photos/1/1 ... img-vi.jpg
morgie
Sweet, that's going to look good. I thought I remembered it being black but wasn't sure. =)
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
thanks, sleeper is my goal hehe
i'll start with the SDSEFI ems-3 for the engine management, but i'll surely switch for a more elaborated one soon (at least one with a laptop connectivity to easily swap maps)
My target is around 17-18psi, will depends on how the injectors will take it .. if i find bargain 550cc ones.. if the tranny supports it .. I will more likely start with 15psi and see how things goes. In fact, i want a fast but reliable daily driver
morgie
Welll. today i went into my first "major" problem...
i thought the left Legacy TT head was identital to a single-Turbo one.. but it wasn't ..
the return hose that taps into the head was pretty different, and interfered with the uppipe .. while being completely incompatible with the hose on the turbo.. as you can see here
it's a good change i have another set of heads so i could take out that hose and put it on my heads. Looking the pics of my Ej22T heads, i think i could have taken the hose from it too.
now it's all right
this was quite an easy problem to solve.. but i was affraid i got stuck there for a while :\
now it's all right
morgie
Swap completely done by now. Pics can be found there :
http://public.fotki.com/morgie/morgie/o ... oteur/swap_!/
also.. some little videos
Engine wont start.. normal, i forgot to line-up the magnets on the damper with the SDS sensor.. :\
http://www.driftquebec.com/videos/morgi ... arting.wmv
After lining that up.. engine starts!
http://www.driftquebec.com/videos/morgi ... tartup.wmv
Can't beat the sound !!
http://www.driftquebec.com/videos/morgi ... /Run06.wmv
inside shoot... sounds even better in real
http://www.driftquebec.com/videos/morgi ... /Run05.wmv
and a mini drift on wet.. i'm the #3 car..
http://www.driftquebec.com/videos/morgi ... /Run04.wmv
Sds is now tuned, i can do the "rodage" peacefully.. i run it only at 6psi, and bellow 4500-5000rpm revs for at least the next 1500km.
morgie
That car looks real sweet Morgie. Sounds like it is a bit of a beast now as well
91 Pearl White Sport Sedan
2014 Volvo S60 T5
18 KTM 1290 Adventure S
97 Toyota 4Runner SR5 - sold
2002 BMW r1150rt-p - sold
2004 BMW r1200ST - sold
2016 BMW r1200RS - sold
2014 Volvo S60 T5
hahah, you're CRAZY morgy!
Is that Platine standing on the side of the car?
Rio Red 90 Legacy LS AWD 174k
Liquid Silver 92 SVX LS-L 88k
Hot damn Morgie!!! That's bad ass. Your car looks and sounds absolutely awesome! Very nice job.
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
That looks really great. Almost as great as that kid with the N/A STI motor a year ago (I know, I just can't let it go).
have you an update?
Running well I hope?
