we got everything disconnected, and the chains hooked up, and the trannie seperates from the engine about 1 inch, then gets stuck.... We have a hunch that it might have to do with the clutch release arm. also.... the actuator arm gets unmovable unless we rejoin the motor and trannie....
Do I have to totally remove the arm to get the trannie seperated from the engine?
Its not coming apart!!!!!
HELP!!!
engine swap....
HELLLLLLLLPPPPP!!! (engine swap problems)
Their is an plug with a allen hex to remove it right over the end of the clutch arm pivot.Take this off then thread a 6mm screw into the clutch arm pivot rod to pull it out.On pull type clutches like the turbo legacy has,The throwout bearing kind of clips into the pressure plate.Good luck, BillC
Oh yea, look for a 10mm plug horizontally near where the starter was. That plug covers the cross shaft for clutch arm. You need to remove that cross shaft.
Todd Erickson
Total Performance Center, Inc.
"Todd the tuner. Can he tune it? Yes he can!!!"
Servicing the Minneapolis MN area.
Todd Erickson
engine swap....
yeah i found that.... all made sense and it popped right out...
now with the new motor we are having issues getting the mounts to drop into the slots on the x-members. the trannie is all hooked up and the motor is close to being ready... its this small damn thing holding me up....
and now i gotta go to work!
engine swap....
Hay Mark, do you know there are any sources you could get the engine
wiring harness for the EJ20T?
I would like to get one for my car since I still using the US ECU
(EJ22T) for my EJ20T!
Please let me know!
Ben
Please let me know!
Ben
engine swap....
You may want to unbolt the tranny and lift it slightly out of the way
to give you more "wiggle room". This will allow for the engine to
slide into the crossmember mounting holes. Then dont tighten the
mount nuts, and reconnect the tranny...and so on
hope this helps
noah
hope this helps
noah
engine swap....
You know what... Try Subaru where you are. Apparently the main warehouse had 1 or 2 of the harness for the EJ20T for LHD cars. Otherwise the big problem is that most wiring harnesses that are available are for RHD cars, no good for us. (I tried, doesnt work - too many wires are wrong.)
Mark
Mark
