well guys, i have the following problem, before this problem occured
i'd driven the car for about 60km at 100km per hour without any
problems, i just parked it in the shed for the night, and the next
day the car wouldn't start
diagnoses so far.
GT 2.0 turbo 1990
i have 3 month old plug packs
i installed new spark plugs last month
when i pulled the fuel line of the injector rail i had heaps of fuel
pouring out when the key was turned.
the motor turns over and triies to fire but doesn't
any help would be appreciated.
cheers
spongynz@yahoo.co.uk
car won't start
car won't start
Well.....the basics are you need fuel, air, and spark in the right combinations.
Have you pulled a plug out to verify that it is truly sparking?
If it's not sparking, I'd check all your coil packs, also may want to check the cam & crank sensors.
