WANTED:EJ18 CARB INTAKE MANIFOLD
monstaru
Post by monstaru »
title says it all.i would love to get my hands on one of these.i am usually over on the USMB but am trying to cover all of my options. thanks guys,cheers,brian :smt100
206er
Post by 206er »
are you gonna set up a distributor too or use the stock ignition?
monstaru
Post by monstaru »
i have a disty setup.thanks,brian
legacymax
Post by legacymax »
When did they use an carb with an EJ18?
-max
95 impreza Rally car. 3.0 H6
88 Toyota fj62 OME lift.
DLC
Post by DLC »
Outside of the US, in the Legacy and Impreza models, usually in Europe.
Legacy Central
legacymax
Post by legacymax »
ok.
-max
EJ22_SLO
Post by EJ22_SLO »
Here in Europe we have "carbed" (monopoint injection) EJ18, Legacy 1st and 2nd gen. In Leone (EA82) we have two types of engine - one pure carb, and the other one is monopoint injection...
If you're looking for EJ18 intake manifold like the bottom one on pics below (upper is from EJ22 N/A)... perhaps i could find one.
monstaru
Post by monstaru »
as long as it will bolt up to an ej22 i will take it.of course i would compensate you as well.what would you take for one and shipping would be to
spokane,washington 99202 USA
thanks, brian
EJ22_SLO
Post by EJ22_SLO »
Ej18 - at the picture wont bolt on Ej22 engine;
problem no1: you can see Ej18 has integrated "water pipe" (EJ22 engine has separated water line),
problem no2: i can tell you it has much smaller diameter.... won't fit...
problem no3: IAC valve, vacuum...
i can take some more comparation pictures and measurements if you want... but i'm 98% it wont fit. at least not without modifications...
monstaru
Post by monstaru »
the water jacket can be taken care of.the smaller diameter pipe is not really a concern.i like to fabricate things.also,from what i hear,it should be a direct bolt up as far as where the heads meet the manifold.thanks, brian
do you have a picture of the bottom?i would love to see it.thanks again,brian
monstaru
Post by monstaru »
bump.........a monopoint or carb manifold is suitable now.
EJ22_SLO
Post by EJ22_SLO »
sorry -this weekend was hell...
bottom side of EJ18 intake maniforld; the gasket is from EJ22 engine - to compare and check the holes.... scale is in metric - cm; there's flap missing on pictures - it was removed it during cleaning; EJ18 ECU is also available.
