what type of oil do you use?
What type of oil do you use?
5w-30
0
No votes
10w-30
11
44%
5w-20
1
4%
5w-30 Synthetic
2
8%
10w-30 Synthetic
7
28%
Other
4
16%
Total votes: 25
Saskatoon Subaru
Post by Saskatoon Subaru »
i'm think'n about doing a oil change on my legacy i just bought and i'm trying to figure out what type of oil i should go with, so whats everyone else running?
2010 Impreza WRX - 265hp
1990 Legacy 267,000km(Rebuild complete 265,423km----March 9/2008)
1991 Legacy Turbo 180,000km
Post by 555BCTurbo »
Mobil 1 10w-30
My motor has 210k miles on it, and has been on Mobil for about 50k of those, and it shows no signs of wear associated with that many miles.
And it does not get driven easily
Bheinen74
Post by Bheinen74 »
castrol GTX 10W-30
91 Legacy Sport Sedan 4eat
91crx si 165k
91crx Si 40.5k
85 BRAT Gl 140
97 SVX 74k
livestrong14
Post by livestrong14 »
Mobil 1 10W-30
91 SS -Carbon Bronze Pearl
EJ257/EJ205 Hybrid
93 Ford Ranger-DD
91 Rio Red SS- RallyX Project
93 AWD Sedan- FOR SALE!
Saskatoon Subaru
hmmm, alot of people seem to like the mobil 1, thats what i was thinkin about going with
asc_up
Post by asc_up »
what about using 20W-50???
that's what someone told me to use awhile ago cause it's a little thicker.
I use Mobil 1 5W and 10Ws changed every 10k mi. A 250k mi tear down of my abused engine (N/A took a BMW 323 up to an indicated 133mph) showed pristine cams, crank, crosshatching on the cylinders, and main bearings that looked good for another 100k.
Murphy
Post by Murphy »
i use Penzoil 10W-30 high mileage
30 is the weight right? and 10 in like a tempature or something, cant remember
the left side of the motor ticks a little, i think a oil vein might be clogged, but i dont have the time to throw at it right now, so i threw in some Lucas oil stablizer and it get alot quieter
1990 Legacy LS, 4EAT
Manarius
Post by Manarius »
I was running 20-50w in my Legacy to keep down the leaking. I changed it every 3000 miles and I wasn't exactly babying the car all the time either.
jackmore
Post by jackmore »
yeah i use Penzoil as well. Its what they recommend in one of the car shops here in NZ
IronMonkeyL255
Post by IronMonkeyL255 »
We use penzoil at my shop, and I'm not too fond of it. It just seems to have more impurities than other oils (darker color).
Personally, I use Valvoline 10w30. I have been thinking of switching to a synthetic blend, but not a full-synthetic. Looking through an article in Tribology and Lubrication magazine convinced me that synthetic oils truly do lubricate better, but it doesn't affect the seals in the same way as traditional oil (which slightly swells the rubber and various other things).
Honestly, though, I need to do a bit more research before switching.
Anyone tried Valvoline's racing oil? Looks to be pretty nice stuff, but definitely not for daily driving.....
Rio Red '91 Legacy SS
Murphy
Post by Murphy »
what about Royal Purple, ive heard people dont really care for it
Stay away from Pennzoil!!!
It has wax in it (meant to quiet lifters and whatnot)...
Stay away!!
jake15
Post by jake15 »
right now i use castrol GTX 10w30, but once i get some more miles on this motor (at about 6k right now) i'll switch to castrol syntec 10w30. i would go with a synthetic oil and change it every 3k if you got a turbo car and you abuse it like you should :lol:
skid542
Post by skid542 »
10W-40 Havoline or Valvoline dino for high milage engines changed around 3-4k. Am I the only one using 10W-40?
Lee
Soul Shinobi
Post by Soul Shinobi »
Castrol GTX 10W40 this summer. I think I'll do 10W30 in the winter and maybe 10W50 next summer if I can find it (might try 20W50). Also, I'm thinking of switching to semi-synthetic.
-Nick
1992 BC Legacy L Sedan AWD 5MT 272,000 - Wish you the best
1998 BK Legacy L Wagon 5MT 234,000 miles - RIP
2002 SF Forester S Wagon 5MT 215,000 miles - Current winter sleigh
1986 FC Mazda RX-7 GXL Coupe 5MT 155,000 miles - Summer cruiser
All_talk
Post by All_talk »
I run Castrol GTX 10W-30, I use to be a Pennzoil man but just seems a bit more sludgy.
A few notes on oil that I have picked up over the years by experience or reading…
What the numbers mean, it’s a hot cold rating, ex. 10W-30… acts like a 10 weight oil when its cold and a 30 weight when its hot.
Stay away from the extended range weights (10W-40, 20W-50), the additives required to create them are not so good for you engine. If you really feel you need a heavier oil for hot weather or hard running you are better off to blend in a quart or two of straight 30W. Just watch the pressure on cold start.
Switching to a heavier weight oil to raise oil pressure dose not lubricate the engine better. Thicker oil is harder to push through the system so you get more pressure but less flow… less oil to the bearings and heads.
Synthetics are good, but not required. Older engine designs (like the EJ22) that were intended to run conventional oils will do just fine on them.
Just my 2 cents
Gary
Soul Shinobi
Hmm, after hearing that I'm thinking of running semi-synthetic 5W30 in the winter and semi-synthetic 10W30 in the summer. Maybe full synthetic if I get a job. :-)
-Nick
Post by entirelyturbo »
Whatever oil you're using now, keep using it. Don't switch brands of oils.
My car automatically has more problems than other Legacies of this vintage, simply because it belongs to me, therefore I leak/use oil more than the average 1st-gen Legacy. 1 quart for every 1k miles.
When I change my oil, I first add about 3.5 quarts of regular Valvoline 10W40 dino, and then add another quart of Valvoline 20W50 dino. This seems to be the best mix between not leaking as much oil and getting good gas mileage.
2000 Subaru Legacy B4 RSK
*Formerly DerFahrer*
Castrol GTX Hi-Mi 10W-30 in an effort to reduce leaking, which is currently very slow. *knocks on wood*
bmxkelowna
Post by bmxkelowna »
Soul Shinobi
I hear the "high mileage" formulas are more or less snake oil.
-Nick
Could be, I've never had a lab do a comparison test or anything. But if I switch back to regular, it'll probably leak more just to spite me. :lol:
