Rallycrossed this weekend...
I didn't even break my car. I finished 3rd in modified 4wd class. I was hoping to run stock class but the tech inspector didn't believe my car was a touring wagon (besides the i/c and the 3" catless exh) . Anyway, I think I did alright competing with cars running dirt tires.
Most importantly though, it was a lot of fun. I recommend this for anyone who likes to go fast and test the limits of their car.
I am jealous of your venue
we roll around on gravel and it hurts..... straight dirt looks so soft
is it private land? SCC land? government facility?
Andrew
16 Outback - wife's daily
95 Gravel Express - Sold
92 Green SVX - RIP
02 WRB WRX - Sold
92 Green SVX - RIP
02 WRB WRX - Sold
It was some old couple's cow pasture. They still graze cattle there the rest of the year .
The ground was pretty soft, but that means more holes and ruts. One car actually rolled when it caught a rut.
Yeah, I remember you. And that car. You should post some pics, if you have any, for the benefit of the other members here. That tire issue was unfortunate. Didn't you're g/f (sorry, didn't actually catch your names) finish 2nd?
the mods you have done to the car will keep you out of the stock classes.
stock means stock.
sounds like you had fun. my advice is to not care about the class and go out and try to beat as many as possible and only look at the OA standings.
find someone running time close to yours and try to beat them.
i preffer gravel myself foir rallyx. it is a lot more predicatble and doesnt rut up as fast.
stock means stock.
96 Impreza L sedan
97 legacy outback limited
00 Impreza RS sedan
00 Impreza RS sedan
Is that from the Brooklyn Bash? I really wanted to make that event, but alas, at the time I had no car for rallying. But as of last week now I do. Well half a car, the other half belongs to a friend/co driver. We took the primitive course back in May and just finally found a suitable car. 93 SS
It seems like the event schedules I've seen are pretty vague, PRG, ORG etc. I hadn't heard about NASA till seeing them mentioned here. What other events are around the Seattle area? Pomeroy and Hillsboro are a bit of a journey. I want to avoid needing a trailer but our car has an oil seepage issue that we have yet to conquer. Don't want to burn it to the ground before we get to rally it so I've been looking for some closer events. Oh and for the WA guys when they say an event is at the ORV park do they mean that place on the way out to Aberdeen on 8?
Thanks for any info.
'93 SS Turbo
'90 L SW drove it into the ground now its dead and gone.
other:'00 A4 1.8t, 02 A6 3.0 Avant
Does it? The PO of our car had a canister style air filter on the car. We haven't been able to find a stock air box for the turbo. Does that mean we will have to run in the prepared class? The rules say something about it being ok to replace an air filter element. Seems a little vague but I assume that means within the stock box.greg donovan wrote: stock means stock.
Also the SCCA book talks about stuff that doesn't add performance. Like improved instrumentation. We want to add oil pressure and water temp as well as a switch to disable the ABS with out sticking our head under the dash to pull the fuse. That should all be cool with the stock rules, shouldn't it?
'93 SS Turbo
Well hello,
Lots of q's.
A few a's: First, there is a rally-x this weekend in Cle Elum. Its put on by Formula Rally x: FRX
Unfortunately I can't make it, even as close as it is.
Second: as for the classifications, I'd say take the car the way it is and shoot for whatever class you want. If you don't qualify you can clarify w/ the tech inspectors about what is prohibited and still get some seat time (which is invaluable) in the next class up. Then correct the conditons that disqualified you for the originally targeted class when you get home. However, be aware that different sanctioning bodies have their own classes and allowed modifications, and they're not usually the same.
Welp, good luck, and find more info here:
Dirtyimpreza
Specialstage
Lots of q's.
Dirtyimpreza
Specialstage
Looks awesome! I can't wait to run my turbo'ed Outback in its first RallyX this coming weekend.
It worries me that a car rolled over when it caught a rut. With my luck, that'll be me.
-'97 Outback - EJ25 block/pistons/HLA heads, EJ22T crank/rods/ECU, EJ20G intake manifold/fuel rails/440cc injectors, VF8 @ 11psi. . . . Fuel cut > me
From what I understand, its a very rare occurance. I imagine the car would've come down on its wheels, had the driver maintained more throttle.impreza_GC8 wrote:It worries me that a car rolled over when it caught a rut. With my luck, that'll be me.
Re: Rallycrossed this weekend...
Sucks when the tech knows Subaru doesn't it?!?beatersubi wrote:I didn't even break my car. I finished 3rd in modified 4wd class. I was hoping to run stock class but the tech inspector didn't believe my car was a touring wagon (besides the i/c and the 3" catless exh) . Anyway, I think I did alright competing with cars running dirt tires.
Closet Legacy owner
Too much throttle is actually what caused the roll-over. Had the driver gotten off the throttle and on the brakes chances are she would not have rolled. Mark it up to experience and move on!beatersubi wrote:From what I understand, its a very rare occurance. I imagine the car would've come down on its wheels, had the driver maintained more throttle.impreza_GC8 wrote:It worries me that a car rolled over when it caught a rut. With my luck, that'll be me.
Closet Legacy owner
