Turbo pistons w/pins, $65 set of four delivered.
Specify the sizes you want, A, B or C.
turbo pistons w/pins, $65 set of four
Re: turbo pistons w/pins, $65 set of four
PM'd to see if you're still around....
janas19 wrote:PM'd to see if you're still around....
Look on the top of the case half's, where they meet. You will see the letters stamped there telling you the correct piston size for each cylinder.
Searching for an EJ22E NA in the Colorado area at the moment but don't have it yet. Before I get it, are the pistons different diameters? Asking out of curiousity and lacking the info.
Yes, they are slightly different in diameter.janas19 wrote:Searching for an EJ22E NA in the Colorado area at the moment but don't have it yet. Before I get it, are the pistons different diameters? Asking out of curiousity and lacking the info.
