As the title states I'm in desperate need of a front drivers side steering knuckle/spindle with a good wheel bearing. Ran with a bad bearing for so long it destroyed the inside of my hub. I can certainly go to a junkyard for one but thought I'd post this incase anyone locally already has one off a car and needs a little cash in their pocket. Looking to pick it up ASAP, been driving my girlfriends fxt and I miss my wagon!
Thanks guys!
Snohomish, WA WTB:drivers side f. knuckle with good bearing
White 1993 L Wagon AWD 5MT-FXT lift, 27” MTs 380xxx miles
White 1991 L sedan AWD 5MT-(Robtune 550 DOHC Ej22t swap coming together) 187xxx miles
Black 2005 LGT 5MT-Ej20x swapped daily, VF40/elh
Re: Snohomish, WA WTB:drivers side f. knuckle with good bear
I have a pair of wrx knuckles, I can go out and check on them here in a little bit, but iirc they felt pretty good when I picked them up.
Awesome! Let me know what the consensus is! Excuse my ignorance but do wrx knuckles bolt right up without any modification? I've honestly never even looked into itcj91legss wrote:I have a pair of wrx knuckles, I can go out and check on them here in a little bit, but iirc they felt pretty good when I picked them up.
I think they bolt right on. Only concern I would have is the abs sensor and the face that it reads its signal off the axle instead of the tone ring on the hub.
It's going in a non-abs car so I'm not too concerned about that!
cool, i pm'd you my number.
