1. has anyone seen a poly or delrin legacy shifter-body mount (like part # 35036) for sale? I havent. they are all for a WRX on which the body mounts and the shifter mounts are perpendicular like this one
http://cgi.ebay.com/ebaymotors/ws/eBayI ... 06636&rd=1
Ive got an idea, but it might have some problems. I was going to try and cut that bushing out of its mounting bracket, drill and tap the body end of the shift linkage for a heim and bolt it up solid, but keep the big rubber bushing at the trans end.
2.does anyone think that would be too harsh a setup?
3.might it cause issues with restricting trans movement? I thought of mounting it solid, but with stock tranny mounts that might be hard on the shift linkage and even the transmission itself. I also thought about a heim at either end of the shifter support linkage but that would surely cause a lot of stress and excessive NVH(which generally I dont mind increasing, but to a point of course).
4. will the big bushings intended for a WRX like this one
http://cgi.ebay.com/ebaymotors/ws/eBayI ... 04182&rd=1
work on my legacy shifter(I think the part # is 35035<NO.2>)? they sure do look like a bitch to put on. are there 2 piece bushings for this mount? in the first auction I posted there are 2 bushings that look like they may be the 35035<NO.2> but I may be wrong. also in the diagram in the sticky on WRX shifters 35035<NO.2> looks 2 piece.
sorry for the long post and maybe Im making this more complicated than it needs to be.
unrelated question: Ive heard that overfilling the trans can be a good idea. how many quarts should I use exactly?
